what do i need to do?
what do i need to do not to lose my bpms?
i have all my music on an external hard drive
geposted Mon 06 Apr 09 @ 8:30 am
Nothing will be changed in this process, the data is on the external drive that matters.
You can save your skins and plug in folders if you want to restore what you have now.
geposted Mon 06 Apr 09 @ 8:42 am
do i just delete the entire vdj folder of certain subfolders
geposted Mon 06 Apr 09 @ 8:49 am
disregard i deleted the entire folder
geposted Mon 06 Apr 09 @ 8:58 am
just dont delete the database file from your external drive.
geposted Mon 06 Apr 09 @ 9:02 am
well it did not fix my problem
When am using VDJ and move the slider over or lower the volume you hear some nast distortion
I disabled the internet cards and still have the problem
geposted Mon 06 Apr 09 @ 9:21 am
That could have been your first post.
Lower the performance settings towards fastest and put the latency on auto with overclock and safe mode unchecked.
Restart the program and check again.
geposted Mon 06 Apr 09 @ 9:25 am
thanks looks like it worked
if i unchecked them that means there not being used
so then what are they for
geposted Mon 06 Apr 09 @ 10:04 am
