Hi all,
I have a question, i currently own the hercules dj console rmx, i'm very pleased off it but i was wondering if i could use the DN-HS5500 with the Hercules Rmx with virtual dj. Becuse there bouth a midi controller i'm not sure if they will work properly.
~bladesinger
~bladesinger
geposted Mon 06 Apr 09 @ 12:09 pm
You can connect more than 1 midi controller and use them both together. Should be fine!!
geposted Mon 06 Apr 09 @ 12:27 pm
but will the audio stream appear on the virtual dj decks when i load them on the DN-HS5500?
geposted Tue 07 Apr 09 @ 8:39 am
