Is there anyone who is using a Laptop with windows XP, P4 or newer and is using the Behringer BCD3000 with virtual DJ pro?
If so, could you explain to me in detail, what did you do to get it to work?
It looks like I was able to get it going, using a Laptop with Window's Vista.
But with Window's XP, I am having a problem.
For those who are thinking, why? LOL....
I already own the following: Hercules MK2, Hercules RMX, PCDJ's DMC, DAC2, and the DAC3.
They all work fine and haven't had a problem with any of them.
This Behringer BCD3000 was given to me by a friend of mine who couldn't get this unit going...
I stepped up to the challenge but man; I haven't been able to figure it out...
Your assistance in this matter is appreciated...
geposted Mon 06 Apr 09 @ 6:46 pm
geposted Mon 06 Apr 09 @ 7:01 pm
I have a BCD3000 working with Virtual DJ Pro with no problems just a couple of clicks and pops that I doesn't happen very often. I did some tweaks and dedicated my laptop for Virtual DJ only and my problems are gone. You have to download the latest driver from behringer http://www.behringer.com/EN/Products/BCD3000.aspx and of course the Virtual DJ 6.0.xx. You can find some tweaks at http://ts.hercules.com/faqs/eng/her_eng_00364.pdf & at https://virtualdj.com/homepage/xeon/blogs/1581/Optimizing_the_system_(WinXP).html if you are using XP. Trust me it helped me alot.
geposted Thu 08 Apr 10 @ 1:59 pm
hey anyone know how to play vinyl with the bcd3000 like so its a line in not time vinyl it worked in vdj5 but now the new mapper is dif the old way was hold (key) and select deck que not any more :( HELP
geposted Wed 25 Aug 10 @ 9:59 pm
bagaimana menyeting bc 3000 dengan virtual dj??
geposted Sat 04 Aug 12 @ 8:59 pm
Ok I also had this issue in windows 7 64bit with BCD 3000 Where the mic would not work!
after doing a google search eventually a yahoo answers page sent me here so I am writing this solution here
You have to set up the sound from the mic inside windows control panel!
First Sound Devices within control panel
Then Click Recording It Should Show the BCD3000 as a line device
Click on it and then select the Listen tab
There is a checkbox *Listen to this device - Check that box is ticked!
After making this setting I can now hear my voice on my BCD3000 Mic Channel
One last thing make sure inside control panel that your BCD3000 is set to default device for both recording and playback by right clicking it and hit set as default!
geposted Mon 14 Dec 15 @ 12:14 am
Thank you gentlemen for timely responses, to this issue. If anyone has any other issues with this controller, please start a new thread, so I don't have to read post from 09, and XP.
LOCKED BY AMAHM.
LOCKED BY AMAHM.
geposted Mon 14 Dec 15 @ 3:50 am
