Im trying to get my numark cdx cd turntable to work with vdj via midi. I have a mid to usb adapter and I use my cdxs for timecoded cd. Is there any way to do that??help me!
DJ Pals
DJ Pals
geposted Tue 07 Apr 09 @ 8:06 am
Not as a MIDI controller, you would have to use a soundcard that would pass the timecode to the VDJ software. I use HDX and am doing it, but I found I need to use the TIMECODE_PRO mp3 file on a CD, it works so much better. The USB to midi wont work.
geposted Tue 14 Apr 09 @ 3:18 pm
What MIDI controller are you using? is it ASIO compatable?....You can get a Maya44 or MK2. The MK2 will alow you to control the software and the Maya is good for external mixers..
geposted Tue 14 Apr 09 @ 3:24 pm
I have a maya44 usb soundcard. which works perfectly
geposted Fri 17 Apr 09 @ 5:28 am
