I want to purchase a Macbook to use with Virtual DJ. However, I have been told by many djs that the Mac version is very bad, and does not work well at all. They say its very buggy and not stable at all. Any reports? The reason I want to get a Mac is for stability anyway. So what is the bottom line? Any fixes or tweaks?
Thanks!
Thanks!
geposted Wed 08 Apr 09 @ 3:50 pm
I haven't has a single problem with the latest (5.2.1) version. The people who told you that are probably using pirate versions of some ancient beta and/or don't have a clue how to use a computer :)
geposted Sat 11 Apr 09 @ 7:07 am
I tested version 5.2.1 for about 4 hours of video with only a single problem at the end. And I think it was my fault because I was experimenting with the program. I think it's pretty stable.
geposted Wed 03 Jun 09 @ 6:12 pm
but there are a few "tweaks" you might wanna do. some registry modifications as well as changing your codecs to quicktime.
geposted Wed 03 Jun 09 @ 6:56 pm
i'm playing also with VDJ 5.2.1 with Mac OSX 10.5.6 and after 4 hours is it a critical moment.... generally chrash.
Restart the program and playing again
That's the only little problem. :-)
geposted Fri 05 Jun 09 @ 7:31 am
i use 5.2.1 fine but i can't even get 6.0.1 to play a song on my macbook so i gave up even trying and went back to serato
geposted Fri 05 Jun 09 @ 12:04 pm
So far its not a 100% stable and that's a fact! I would not recommend for live dj use...but great home fun.
geposted Fri 05 Jun 09 @ 5:21 pm
If you talking about v6.01 mac, of course it is not as it is still a beta:)
Of course, you can help by participating on it;)
geposted Fri 05 Jun 09 @ 5:54 pm
what i dnt understand is why the vci 300 xml files works beter on 5.2 version ..and on 6 the jogwheels suck...so im back using the old version.....the are not using the same middi mapping?
geposted Sat 06 Jun 09 @ 3:06 pm
