OK heres what i want to do, basicly just create a VIDEO playlist, (that part i know how to do)
i need to make the playback video window open up FULLSCREEN on the same window as the controls
so to be clear, im opening the program, opening a playlist, setting it to automix, and then opening the video window and wanting to run it fullscreen IN THE SAME WINDOW AS THE CONTROLS, NOT THE SECOND SCREEN,
if i take the window and drag it to its max size it still shows a blue bar at the top
geposted Thu 09 Apr 09 @ 3:52 pm
I can get the blue to disappear by dragging it to fill screen, then grabbing on the bottom of the blue bar and dragging it up.. Still see the line, but not the bar. Hope that helps
geposted Thu 09 Apr 09 @ 4:21 pm
is there a option somewhere to go fullscreen on the main monitor?
geposted Thu 09 Apr 09 @ 4:56 pm
Nope. You wouldn't be able to see the browser etc... then, rendering the software pretty useless.
geposted Thu 09 Apr 09 @ 6:12 pm
I have done this before to offer a quick karaoke ability.
Your graphics card better be up to snuff or you could be asking for trouble though.
When you strecth the video window you destabiize the software somewhat, ok if your system can handle it.
Once full screen you can jump back to the vdj interface by hitting alt/tab quite easily.
geposted Fri 10 Apr 09 @ 6:54 am
Sorry, I assumed he meant proper fullscreen rather than just resizing the video window!
geposted Fri 10 Apr 09 @ 9:39 am
