Peace All.
I'm having an issue with the virtual vinyl When I Go To Sound Setup And Choose 1 Turntable it docent read the time code, But When I Choose Two Turntables it reads the time code then i have to disable the left deck and use the jog wheel,That's originally what i want to do but when i change skins i cant disable the left deck how do i disable the left deck all Together ?..............Thanks In Advance......
Set Up - Hercules RMX, Vestax-03A 2 Ch Mixer, Staton Str8-60 Direct Drive TTB
geposted Fri 10 Apr 09 @ 3:41 pm
you only get 5min of time code with the LE thats why I suggest you try the trial version of PRO
Do you have TCV? also in the sound set up make sure the RMX is enabled should be selectable in the sound cards.
Also what version of VDJ you running with? your going to need to be using 5.07 or later for VDJ to reconize the RMX
geposted Fri 10 Apr 09 @ 3:54 pm
I Do Have Pro......
geposted Fri 10 Apr 09 @ 3:56 pm
