Have all new versions soft/hardware, PC specs are on point.......
When I load a song while a song is playing it partially mutes the song that is playing
Almost seems like the songs are coming out of different speakers, my output is master/headphone
When I use the RMX the same thing happens, maybe I am being stupid with the Cue and the master/cue knob?
At any rate, when I do my next show I am worried that when I load a song it will mute the current song playing or partially mute it.....
Any thoughts or ideas are greatly appreciated--------------THANKS!
geposted Sat 11 Apr 09 @ 12:16 pm
On the RMX when you load a song, the headphone mix automatically pans to that side. Sounds like you have your headphone mix playing through the mains.
geposted Mon 13 Apr 09 @ 4:32 pm
thanks man, i will check that out
i appreciate your help
geposted Thu 16 Apr 09 @ 11:17 am
