Is there a way to find the Camelot/BPM of several songs without having to load individual songs one by one?
Am I an idiot?
THANKS!
Am I an idiot?
THANKS!
geposted Sat 11 Apr 09 @ 12:19 pm
if they are scanned already..........right click on the little box next to title (below the search bar) to enable
geposted Sat 11 Apr 09 @ 12:33 pm
thanks for the response man, i appreciate it....
is there a way to scan all of the songs in order to get the camelot/bpm---i understand how to have it as a column header, just wondering if there is a way to scan more than one song, or how vdj scans songs in order to retrieve this info regarding camelot/bpm
as of right now that info (camelot/bpm) doesnt show up until i have loaded the song......
geposted Sat 11 Apr 09 @ 3:10 pm
You can highlight one or multiple using the standard (hold shift key) then right click and select the BPM scan - this will scan all the highlighted songs! =)
geposted Sat 11 Apr 09 @ 3:15 pm
right on-------
im taking it one step further and right clicking entire folders for the scan
once scanned for bpm the camelot pops up
problem solved
thanks
problem solved
thanks
geposted Sun 12 Apr 09 @ 12:18 am
