I've been using the Virtual DJ software on my MacBook for a month or two without any problems until now. When I drag and drop a song into the cue area, it loads successfully, but when I try to play the track, Virtual DJ doesn't do anything~
Does anyone have any suggestions?
Edit: Problem resolved.
Config > Info > Reset to factory settings
geposted Sat 11 Apr 09 @ 12:38 pm
Glad you managed to solve your problem.
As a Mac user who has been using the software for a few months i would assume you have purchased the software, in which case please register your serial number here https://virtualdj.com/users/edit.html
If you havent already purchased the software then please do so here https://virtualdj.com/buy/ as using cracked software is very unreliable especially on the Mac OS.
geposted Sat 11 Apr 09 @ 3:40 pm
