i have a korg nano pad that has a x y touch pad that i would like to use for controling the effect sliders
its all midi and i have no prob with the drum pads but i cant figure out how to map the x y pad to work with vdj
thanks for any help
thanks for any help
geposted Sun 12 Apr 09 @ 1:36 am
bump
is anyone here using a pad with virtual dj? if so, how did you map it
geposted Sun 12 Apr 09 @ 11:41 pm
i hate to tripple post but i know a lot of users use this or the kaos pads or other pads
before my trial runs out and i got back to traktor can someone please give me a hand
geposted Mon 13 Apr 09 @ 4:24 pm
Open config and then remote control.
Right click on General Midi
Click activate
Then Click Config
Here you will assign each of the player's features as you would in keyboard shortcuts by moving the knob, button or fader/slider to sent a note value to the program.
Then click add, move the button or slider and find the appropriate assignment for it.
Click ok after all assignments have been made and you should be set.
Click activate
Then Click Config
geposted Mon 13 Apr 09 @ 4:38 pm
one thing I did with my Nano pad is you may have to disable the touch/release on the X/Y pad because it sends a midi signal also that can get jumbled in with the x or y midi cc.
but I have mine setup as...
X = slider 1 for effect
Y = slider 2 for effect
it's basic but it does exactly what i need
geposted Tue 14 Apr 09 @ 7:29 am
thanks nate, the touch release was the problem
geposted Tue 14 Apr 09 @ 12:23 pm
