hi
i try to step over from another DJ program to Virtual DJ
now i'm trying to do some DJing but i have one big problem. When i use the Crossfader it makes noise (you can hear it in the song than) --> audio dropouts etc.
my computer is strong enough to use Virtual DJ so that isnt the problem.
Not only the Crossfader makes noise btw... all buttons makes noise when i hit one.
can someone help me pls ???
gr. robb & thx allready
geposted Wed 15 Apr 09 @ 5:46 am
Maybe you should set the Audio Latency in the options to AUTO and disable safe mode and overclock! OR You need a better soundcard! :-)
geposted Wed 15 Apr 09 @ 5:57 am
thx... it works perfect now!!
geposted Wed 15 Apr 09 @ 6:09 am
hope to see you as pro user soon! :-)
geposted Wed 15 Apr 09 @ 6:18 am
I had this problem too, until i read this topic.
Thanks for the help also....
geposted Mon 11 May 09 @ 8:20 am
FUCK! I can't believe how stupid how was!!! Trying everything but the safemode!!!
geposted Wed 08 Jul 09 @ 4:14 pm
