I currently use an RMX as my mobile unit, i am looking to upgrade and use the RMX as a backup unit. The 2 units im looking at are the DMC2 (nicely priced), DAC3 and the HC4500 (like the option for cd connection).
I would like to get some feedback on which one people prefer, i'm working on getting more and more gigs (birthday parties, small weddings etc) and would like a reliable rig.
Thanks as always for your assistance.
Pete
Pete
geposted Wed 15 Apr 09 @ 7:01 pm
I have the denon hc4500 and highly recomend it. i use the jpboggis mapper and vmix skin. I am gonna eventually get the cd players to link to it for back up.
you cant go wrong with the denon
geposted Wed 15 Apr 09 @ 7:26 pm
gotta go with denon. pcdj doesn't even make DJ equipment and you can tell in the DAC 3, I hate mine. i'm saving for the hc4500...
geposted Mon 20 Apr 09 @ 1:54 am
I have a DAC 3 and a Denon HC4500, Denon is light years ahead of the DAC 3. Use the mapper as mentioned above and you'll love it.
geposted Mon 20 Apr 09 @ 6:59 am
do you have to have a mixer that works with the HC4500 and if so which one? thanks
geposted Mon 20 Apr 09 @ 7:22 am
You can use w any mixer.But you can use it w a denon mixer to control the the crossfader on the software.
geposted Mon 20 Apr 09 @ 10:28 am
As mentioned by djbojett any mixer can be used. I'm using a RANE MP44.
geposted Mon 20 Apr 09 @ 10:32 am
That Rane Club Mixer looks really Good a little out of my budget. I was looking for a Denon Mixer to go with the HC4500 But have not seen any packages around
geposted Mon 20 Apr 09 @ 11:49 am
If i go with the hc4500, ill be using the Denon x500 mixer.
geposted Mon 20 Apr 09 @ 11:50 am
You should get either the Denon X500 or X900 mixer.
Both of these can be linked to the HC4500 via the X-control cable - This allows you to video crossfade using the mixer's real crossfader.
geposted Mon 20 Apr 09 @ 12:30 pm
