How are these cdj 400's w/ vdj do u like the performance
geposted Wed 15 Apr 09 @ 8:25 pm
Pretty well. I've been running the 2xCDJ-400 + DJM-400 setup with Virtual DJ and have ran into very few problems. The latency between them is very minimal, however it all depends on your system specs pretty much.
The effects work perfectly (3 each cdj).
geposted Sat 18 Apr 09 @ 11:55 am
How did you set everything up?? im having so much difficulty setting up my 2 cdj400s and djm 400. I cant get any sound at all?
geposted Sat 18 Apr 09 @ 7:40 pm
Open VDJ go into preferences, Sound then set to external mixer, and soundcard to ASIO on CDJ-400's. I have mine set up with a DJM-800 mixer but the settings shouldn't be much different for other mixers. Make sure you have ASIO4ALL downloaded. It's freeware.
I'm sure someone here can be more specific on the details of what have put here.
DJ RuDeDoGG from SoCali!!
geposted Mon 20 Apr 09 @ 2:00 am
it says that there are not enough channels.. when i try to configure the asio card
geposted Mon 20 Apr 09 @ 6:43 am
geposted Mon 20 Apr 09 @ 7:03 am
