is there a way to simulate switching turntable speeds in virtual dj?
For example:
I want the track to be playing normally, but when I click a button, the speed would drop to that of what it would be if I was to press the 33rpm speed on a 45rpm record.
Is there an effect or keypress I can use to simulate this action?
For example:
geposted Fri 17 Apr 09 @ 10:32 am
In Config - Options - Disc(right side down corner)
geposted Fri 17 Apr 09 @ 11:07 am
doesnt that just change the speed of which the graphical disc rotates and nothing to do with the actual sound?
I dont care what it does on the screen i never look at it, it want to be able to mimick the actual effect on the audio.
geposted Fri 17 Apr 09 @ 11:14 am
Actually I think it was an effect on the jogwheel and scratchwheel actions too. But no, it doesn't do what you want.
I haven't done the maths, but you could make a keyboard shortcut that will drop the pitch by about 25-30%? Doing so would mean your pitch range would have to be 33% at least (you could macro it) but the new range will obviously affect both decks. The value of the pitch change would probably need a value of around 400 with a range of +-33%.
geposted Fri 17 Apr 09 @ 11:33 am
