hi my mixlab v3 skin doesnt have the eq crossfader option . it would be handy to have it . see it on youtube i only seem to have eq1/2 for the mixer
geposted Fri 17 Apr 09 @ 11:06 am
Mixlab 3.1 that is supplied with the current VDJ versions has three EQ crossfaders between the two waveform displays.
geposted Fri 17 Apr 09 @ 11:12 am
yeah i aint got it for some reason flicked through the options for the eq settings. it doesnt have the 3 crossfaders for high/mid/low
geposted Fri 17 Apr 09 @ 11:21 am
They aren't in the EQ settings panel that is switched, they are above it. What version of mixlab do you have?
geposted Fri 17 Apr 09 @ 11:34 am
its v3.1. i got timecode sat were they should be
geposted Fri 17 Apr 09 @ 12:09 pm
sorted now
geposted Fri 17 Apr 09 @ 1:10 pm
