guys just cleaned my files ect how do i find hidden files
geposted Fri 17 Apr 09 @ 3:39 pm
what is your O.S. ?
geposted Fri 17 Apr 09 @ 3:57 pm
windows mate
geposted Fri 17 Apr 09 @ 4:02 pm
Vista or XP?
Which Service Pack?
Which Service Pack?
geposted Fri 17 Apr 09 @ 4:16 pm
xp with service pack 3.sorry for being short bjut want to be to the point
geposted Fri 17 Apr 09 @ 4:18 pm
In this case I can help you since I have the same O.S.:
go in C:/ where you can watch all folders you have in your hard-disk, Instruments (near to the "?"), Option folders, Visualization and on the top of that window you can see Folders and hidden files.
Move from not to display.. to display.
P.S: my O.S. is in Italian language so try to get by on your own about my words.
geposted Fri 17 Apr 09 @ 4:23 pm
i have did this before all files are shown mate
geposted Fri 17 Apr 09 @ 4:35 pm
Good.
Enjoy your shown files :)
geposted Fri 17 Apr 09 @ 4:38 pm
problem is still showing i have over 2oo hidden files
geposted Fri 17 Apr 09 @ 4:40 pm
that's not possible.
How are you figuring you have still 200 hidden files out?
geposted Fri 17 Apr 09 @ 4:43 pm
do you mean hidden files in the browser > fix setting. im looking into this myself!
geposted Fri 17 Apr 09 @ 4:48 pm
in vdj clean fix ect part says i have hidden files
geposted Fri 17 Apr 09 @ 4:52 pm
djstaffy, I am not able to figure your problem out.
Could you explain better to us?
Where are you seeing hidden files?
geposted Fri 17 Apr 09 @ 4:54 pm
I think the hidden files are hidden from the database - if you re-scan the folders it should add everything back to the database.
I beleive...... :s
I beleive...... :s
geposted Fri 17 Apr 09 @ 4:56 pm
i will try this.it is in my check clean fix part of vdj mate.its saying i have 212 hidden files.dont know how to find them.
ok i have re added my music to database and all clear thanks guys for your help
geposted Fri 17 Apr 09 @ 4:58 pm
\no problem, glad it worked :)
geposted Fri 17 Apr 09 @ 5:03 pm
