Hi,
I want to buy a couple of CDJ-400 and use VDJ with my MK2 console as a mixer.
1- Is it possible to use the CDj's with the MK2 console as the mixer?
2- I've heard that the Numark ICDX might be a better solution (cheaper and more precise), what are your thoughts?
geposted Fri 17 Apr 09 @ 9:01 pm
You can, if you are adding software to that.
CDJ 400 controls the deck in the software, and a midi mixer controls the mixer section in the software.
But a midi mixer cant mix witout a dj software in use ;)
geposted Sat 18 Apr 09 @ 8:20 am
WHat has to be done set-up wise to get the DJ console MK2 to work with the VDJ and my 2 CDJ-400?
geposted Sat 18 Apr 09 @ 1:10 pm
If you have the Pro Level Software it will allow you to hook up midi controls and soundcards desired. The Home Edition or LE version is limit controller functionality.
geposted Sat 18 Apr 09 @ 1:28 pm
