Hello,
I wanna buy this:
-ESI Maya 44 USB
-2 numark vinyl timecode vinyls
I have:
-CUE
-2 belt drive turntables
-mixer
My question is:
Does this work, or is belt drive not made for this?
And what vinyls do i have to work with CUE?
thanks,
I wanna buy this:
-ESI Maya 44 USB
I have:
-CUE
-mixer
My question is:
thanks,
geposted Sat 18 Apr 09 @ 7:01 am
Yes the timecodes will work, but belt driven TT's are not the best. Ideally you need direct drive TT's.
For your vinyls, you can use VirtualDJ's, Numark vinyls or Serato vinyls (if you choice the noise map engine in the timecode config)
geposted Sat 18 Apr 09 @ 8:16 am
