Did anyone compare them yet, which is better for us?
geposted Tue 21 Apr 09 @ 2:46 pm
Both should work the same with VirtualDJ
But, if you have a external sound card already then go with the Steel. It has no built in sound card.
If you haven't a sound card then go with the RMX.
geposted Tue 21 Apr 09 @ 2:50 pm
Thanks Jimmy. How about the construction difference IE: the wheels, etc?
geposted Tue 21 Apr 09 @ 2:59 pm
They are the same..only difference, as Jimmy pointed out, is the sound card.
geposted Tue 21 Apr 09 @ 5:33 pm
Ok, thanks to both. Here I thought something new and exciting was out. I have a sound card but I like the all inclusive so I'll prob get the RMX.
geposted Wed 22 Apr 09 @ 7:49 am
Love the RMX Console, I recommend highly!
geposted Mon 11 May 09 @ 12:37 am
