Hello everyone,
I installed the program, But to the surprise of evil i am getting this error message:
VirtualDJ
Installation Error
OK
and thats it, it doesn't let me continue.
here are some of the thing i have tried:
1.) i uninstall the program and clean all the dir and registry.
2.) i used ccleaner after all of this to clean changes in my pc.
3.) i re-installed the program again, but still nothing, still the same.
does anyone here know a solution for this issue?
Thanks in advance
geposted Wed 22 Apr 09 @ 4:17 am
Is this the trial version you are stuggling to install - if not where did you obtain you copy?
geposted Wed 22 Apr 09 @ 5:37 am
Hi
are you saying that because of the: "No license user" ?
well yes, i am a No license user, and about this istallation
i downloaded from website that is call Old versions.
Now i would like to ask you something, does this site really worry
if users or visitors are a No license user? ...please let me know that
way i will not ask any other question in here and i will forget about
this open question.
Thanks
geposted Wed 22 Apr 09 @ 7:08 pm
sam i think you misunderstood, dan is a very capable guy who will help you if he can, all he needs to know is which version you are running so he can understand your problem better, and no dan doesn't differentiate between users he helps everyone regardless.
geposted Wed 22 Apr 09 @ 7:15 pm
I am merely trying to establish what your problem maybe. In your original post you make no reference to which version of vdj you are trying to install or what kind of system you are tryingto install on- windows or mac etc etc.
I wasn't trying to offend but simply obtain more information from you! If you post some more information here I will endeavour to help you.
@tayla- thanks for your support.
geposted Wed 22 Apr 09 @ 8:10 pm
Disable Nod32 antivirus when you install Virtual DJ
geposted Thu 23 Apr 09 @ 1:57 pm
I've disabled Nod 32 and still get the same message installation error? Anything else?
geposted Tue 05 May 09 @ 7:34 pm
Sure you disabled it the right way?
Its a known issue with Nod32
https://virtualdj.com/forums/105923/PC_Version_Technical_Support/installation_error___Disable_NOD32_anti_virus.html
geposted Tue 05 May 09 @ 7:51 pm
is there a link here for old versions ? i didn't see it
geposted Tue 05 May 09 @ 9:44 pm
Where you got the information to fix your problem? HEre on the e-service?? or where?...
If you download the Trial version from here, from this webpage, you can test the software for 20 days without restrictions in it.
Good Luck!
Good Luck!
geposted Wed 06 May 09 @ 3:59 am
Why are you downloading form "old versions" when the current trial is available here?
Please try that and let us know how you get on.
We are all here to help, especially NLU's. I will not support people who are blatantly using illegal software but if you are trying to install the legitimate trial then we will help all we can.
Please let us know your OS and the version you are trying to intall.
geposted Wed 06 May 09 @ 6:52 am
