Ok I have a PC using vista with VDJ and I been doing parties for a while now..I'm bout to get sum club gigs.the clubs uses a Serato soundcard I use a maya..if was to get a serato sound card will it work and do i need any downloads..cuz unhooking and hooking wires back can be a hassle... and the othere djs uses serato..
geposted Fri 24 Apr 09 @ 11:50 am
You need the Pro version of the software first ...
geposted Fri 24 Apr 09 @ 12:01 pm
I have the pro version been had it jus aint put on the site yet. can't find serial number my girl open the box thought it was something else...
But will it work mr DJ Man
geposted Fri 24 Apr 09 @ 1:14 pm
Lol ... heard that one before ...
But ... you asked if it will work correct? And I said you need the Pro Version. That is your answer ... you need the Pro Version for it to work.
geposted Fri 24 Apr 09 @ 1:32 pm
