guys whenever i open my hd sticks there is a folder saying trashes what are theese folders.
geposted Sun 26 Apr 09 @ 5:04 am
are you switching your hd between mac and windows??
geposted Sun 26 Apr 09 @ 5:13 am
yes when im transfering files mate
geposted Sun 26 Apr 09 @ 5:14 am
It has something to do with Mac OSX - quite why it does it i do not know.
I think (if i remember rightly) i fixed it by formatting it on the Mac using the default format setting (obviously backing everything up first). Then it doesnt seem to show up anymore.
If that doesn't work then let me know and i'll see if i can remember what i else i did.
geposted Sun 26 Apr 09 @ 5:20 am
not sure what the formatting area is.can i just delete theese files trashes or do they hold info
geposted Sun 26 Apr 09 @ 5:49 am
you can just delete them - but i think they will keep coming back.
If you wanted to format it on your Mac - go to APPLICATIONS--->UTILITIES---->DISK UTILITY
geposted Sun 26 Apr 09 @ 5:56 am
what ecactly is formatting what does it change
geposted Sun 26 Apr 09 @ 6:05 am
it basically erases everything and changes the memory into a Mac compatible format. Windows is still able to read the drive without a problem but it should stop the "random" files from appearing.
geposted Sun 26 Apr 09 @ 6:25 am
ok get ya thanks mate
geposted Sun 26 Apr 09 @ 6:33 am
