Hey folks, does anyone know of a free downloadable software that allows you to make a cd with sepparate tracks but no delay when one track changes to the other like on euphoria or hed kandi cd's? eg. when i record an hour long session on vdj and it is made up of 16 songs, can i put these onto a cd as separate tracks but without a pause in between every song? Cheers
geposted Sun 26 Apr 09 @ 5:28 pm
Theres options in all cd burning programs that I know of to reduce the amount of delay between tracks. If you change the delay to zero it will continue to the next song with no break. Windows Media Player, Itunes and Nero have the option.
geposted Sun 26 Apr 09 @ 11:17 pm
Or you can use the trial of Sony CD Architect as you run your mix through it you you can put the breaks in by hitting 'T' when you burn to CD
You get the number of tracks shown i.e. 12 etc but no breaks in the mix, just like the the ones you mention :-)
geposted Mon 27 Apr 09 @ 10:27 am
whats a good software to use when burning on to a cd, because i can record my mix using the cd part of virtual dj but it doesnt let me open it on a program, any help please. thanks dj jon
geposted Wed 13 May 09 @ 10:18 pm
