Hi
this has probaly been asked before but im having a bit of trouble. I need to reset my search database as i have deleted a load of tacks from my external hdd but the search still finds the results.
This is strange as i have recently reinstalled windows onto a second partition, reinstalled cue 5.2 and cleaned up my external drive before hooking the drive up to my laptop
The history and playlist section is empty as i would expect and the browser only lists the current tunes, however the search finds all the deleted stuff.
I have tried the clean fix and check options but they never seemed to do anything.
Any advice would be most helpful
Dave
Dave
geposted Mon 27 Apr 09 @ 11:23 am
1. You need to select the deleted tracks and select remove from database.
2. You need to recurse your folder or folders...select all....then select remove from database......then re-add them in the same way.
3. Delete your database file stored on your external drive, open VDJ and re add your folder or folders.
One of these options should help you.
geposted Mon 27 Apr 09 @ 2:58 pm
