To whom the reader is,
I recently bought Virtual DJ for Mac verison 5.1 or 5.2(not sure).A great program but I have a burning question that I would like to be answered.HOW ON EARTH DO I CREATE A REMIX!!!Is it possible to take out the vocals of one song then use the music and put it on another song which only has vocals?But all in all I want to know if it's possible to create a remix of a song using VDJ.
Thank you so much,
Good DJing!!!
Thank you so much,
Good DJing!!!
geposted Tue 28 Apr 09 @ 7:49 pm
VirtualDJ is not a production program, it is a DJ program. Try looking into Fruity Loops, or a similar program, and see if that is more in line with what your trying to accomplish.
geposted Tue 28 Apr 09 @ 8:11 pm
You can remix on the fly using loops and kill switches on the EQ, dubbing it and adding effects. A bit tedious but it's a practice of skills.
geposted Mon 04 May 09 @ 9:38 am
I usually do remixes live in a club, using sampler, cues(go to cue), loops and both decks.
however e.g. using two decks is better for me - it provides better control to have beats/parts of songs in a good sync than
just using synchronised samples to beats.
geposted Fri 22 May 09 @ 11:55 am
Practice, Practice, Practice
geposted Mon 15 Jun 09 @ 9:40 am
here i did a couple of remixes check it out straight off a hercules rmx and virtual dj. very simple bro.
http://www.filefreak.com/files/33637_zbehz/alica%26pac%20%28locoz%20remix%29.mp3
geposted Mon 06 Jul 09 @ 11:42 pm
