Is there a setting which reverts the the actual set pitch to its default without pressing anything ?
Im using the vci 300 with latest virtual dj setup and skin is cue 1.8
ive also tested this on other skins
this is the midmaping i have set for that key
note note="41" action="sync" chan="1" />
only other option is to tick auto and try using actual beats
but it seems like sync is acting like an off on switch press it once for the sync and another to reset
after multiple presses it has like a huge fluctuation in pitch
also pressing it long time and releasing also resets it
perhaps im missing another action on the same note
Any advice would be greatly appreciated as this setup is soon to go live
pc specs monster i7 6 gig ram raid velocaraptors
average latency 75
average latency 75
geposted Thu 30 Apr 09 @ 11:30 pm
