Yes, hi.
I downloaded the trial version to get a view of the software before I purchased this program. I cannot open the trial. When I try it says "Select Interface". No matter what interface I select, it tells me this error: "Invalid skin file (error line %i in the xml". What is this issue and how do I fix it?
geposted Sat 02 May 09 @ 10:51 am
This usually happens when there is a bad skin loaded. Did you try rebooting? Do you have any skins, except the default skin installed?
geposted Sat 02 May 09 @ 3:13 pm
No, I have whatever came with the download.
I was told to delete the install file, uninstall, reboot, and then install. Did not work.
geposted Sun 03 May 09 @ 7:49 pm
Did you download the software from here? or another source?
geposted Mon 04 May 09 @ 5:32 am
i have the exact same problem, i have deleted this file and downloaded it again twice and yet it still doesnt work
geposted Fri 12 Jun 09 @ 12:22 pm
It helps if you report what operating system you are using ...
geposted Fri 12 Jun 09 @ 12:38 pm
