Hi Everyone out there, I wonder if anyone can help me i have been trying to get mpeg2 videos to load on my system but to no avail all i get is an error message any idea????? I also have a collection of mpeg2 visuals for use through clipbank and they load in clipbank perfectly, just nothing at all in peg2 format will load on the player itself.
I have been through the codec settings a million times now and am fast losing patience
PLEASE HELP
Steve
PLEASE HELP
Steve
geposted Sun 03 May 09 @ 11:55 am
Make sure your using VDJ video decoder is selected under codecs. That is what I have selected and works fine for me.
geposted Sun 03 May 09 @ 12:05 pm
You could also download K lite codec pack and install them.
geposted Sun 03 May 09 @ 12:08 pm
Done that but still no joy, vdj does recognise them as a vide but just throws an error up when i try to load
geposted Sun 03 May 09 @ 12:10 pm
VDJ normally plays MEPG-2 without any codec issues, as far as I'm concerned it's the standard video format.
Your problem must be within the VDJ program but it's hard to diagnose anything without knowing what you have, is this a trial version or something else.
I'm more than happy to try and help you but I need more information.
geposted Sun 03 May 09 @ 2:20 pm
Do they play in Windows Media Player?? Try renaming one to .vob from .mpg.
geposted Sun 03 May 09 @ 5:17 pm
Are you sure that the video file exists there where vdj database expects? Check video file info on vdj. I got these errors once when my OS set the external hard drive to different drive letter than usually.
geposted Mon 04 May 09 @ 7:43 am
HD MPEG2 video does not work on the default video decoder supplied with VDJ. To fix this go into config, codecs, highlight the MPG file and change it from Video Decoder to Windows Media Player Video Decoder.
This will fix the problem, but as suggested you may also have to add Klite decoers and have them add during install the Windows Media Player.
If you get time and a few dollars, buy a registered version of VDJ too. Cheers
geposted Mon 04 May 09 @ 7:56 am
hi folks,can ne one tell me how to load the database, so i van access my music etc through the search browser,also when i try to video tracks the picture comes on but it has vertical ,lines across the screen. any help would be appreciated.
geposted Tue 05 May 09 @ 10:20 am
