a professional computer geek told me that quad is good for cs4 and 3d studio max.
he said that for dj use. it's better to use duo.
is this true?
response from vdj developers very appreciated.
dj shahar
is this true?
dj shahar
geposted Sun 03 May 09 @ 2:17 pm
Nothing wrong with using a quad core at all for DJ'ing purposes - the more power the better I say. Of course it does depend on the clock speed of each core as to which is better. Another point worth noting is that you get one DPC queue per processor.
geposted Sun 03 May 09 @ 5:38 pm
For DJ use. Duo Is enough. there are DJs using still using single centrino processors and they work fine. For games using high graphics, use quad.
geposted Sun 03 May 09 @ 6:29 pm
If you can afford a laptop with a quad, go for it but a duo will work, it's all about IRQ assignments. If you know how to undo the ACPI mode in your laptop, and assign different IRQ's for each USB port(good if you are using vinyl control and midi for effects at the same time) and sound card. Also turn off the wi-fi and on board LAN during performance.
geposted Sun 03 May 09 @ 9:18 pm
so which is better for mixing audio?
and which is better for mixing videos?
these are my options: quad 2.53 or duo 2.93
geposted Mon 04 May 09 @ 11:51 am
I don't think you'll really notice a difference in truth.
I've got a system that is a 2.40GHz quad, and a system that is 2.80GHz duo. Neither ever get really stressed out.
geposted Mon 04 May 09 @ 3:11 pm
I would say if you can afford the Quad, go for it. I would rather have too much power than not enough. And who knows what VDJ version 6 will bring. Build for the future, not the present I say.
geposted Mon 04 May 09 @ 9:09 pm
I really don't know if XP supports quad core, unless there is an XP driver out there. I prefer the VDJ performance with XP...hate vista. I think the duo will work depending how much hardware and process you will operate simultaneously.
geposted Mon 04 May 09 @ 9:45 pm
Microsoft software licensing looks at physical CPUs, not number of cores.
XP Home supports 1 physical processor so you could run one quad core CPU.
XP Professional supports 2 physical processors so you could run dual quad core CPUs.
geposted Tue 05 May 09 @ 3:46 am
I never knew that .... thanks for the info Scott!
geposted Tue 05 May 09 @ 4:41 am
No problem :)
http://www.microsoft.com/licensing/highlights/multicore.mspx
Quote :
Q. How does this licensing policy affect products such as Microsoft Windows XP Professional?
A. Microsoft Windows XP Professional and Microsoft Windows XP Home are not affected by this policy as they are licensed per installation and not per processor. Windows XP Professional can support up to two processors regardless of the number of cores on the processor. Microsoft Windows XP Home supports one processor.
geposted Tue 05 May 09 @ 5:13 am
in the end overpriced dell laptop returned w/o hassel and bought an hp
HP HDX16t Premium Series customizable Notebook PC
* • Genuine Windows Vista Home Premium with Service Pack 1 (64-bit)
* • Intel(R) Core(TM)2 Duo Processor T9800 (2.93GHz)
* • 8GB DDR2 System Memory (2 Dimm)
* • FREE Upgrade to 320GB 7200RPM SATA Hard Drive from 250GB 7200RPM SATA Hard Drive
* • 1GB Nvidia GeForce GT 130M
* • 16.0" diagonal High Definition HP Ultra BrightView Infinity Display (1920x1080p)
* • Lightscribe Blu-Ray ROM with SuperMulti DVD+/-R/RW Double Layer
* • Webcam + Fingerprint Reader with HP Imprint Finish (Fluid)
* • Intel Next-Gen Wireless-N Mini-card with Bluetooth
* • 50% OFF!! HP Integrated HDTV Hybrid Tuner
* • Full Size Backlit Keyboard
* • 6 Cell Lithium Ion Battery
* • System Recovery DVD with Genuine Windows Vista Home Premium (64-bit)
* • No Productivity Software
* • HP Home & Home Office Store in-box envelope
I decided to go with this because frankly, it's 3k$ less and has more hdd, more ram, and higher cpu ghz.
thanks 4 all the help.
tell me what you think about this laptop? but please don't be too mean. this is new. :)
geposted Tue 05 May 09 @ 10:11 pm
My opinion is that it doesn't matter what we think but if the system works!!! Obviously its going to work audio but as I remember you use vids so thats the real test / question. Test the hell out of your video card. I got my laptop for 600.00 yr for doing vid edits but turned out it works flawless with vids, audio, TC and everything in between...Bottom line is that you have to use it, make sure it works for your needs.
geposted Tue 05 May 09 @ 11:27 pm
yeah quad is awesome for anything whether it be dj.ing gaming or just to have a super fast computer. but it really doesnt matter what system you have a single core CPU with a 1ghz processor will run VDJ quite amply al long as you dont have it stuffed up with junk and you use an external hdd to store your music.
what im saying is choose what ever you want, there is no good of bad and no right or wrong, as long as it does what you want it too. in my personal opinion and if it were me trying to decide i would go for the quad in an instant. this is purely because it will be future proof and will last another 4-6 years before being out dated. i have used VDJ on both my laptops and recieved pretty much the same performance from both the single and the dual core systems.
just be sure to choose carefully and choose wisely, weigh up all the differences and all the good and bad points of each system before you jump in and buy the one you regret later on.
geposted Wed 06 May 09 @ 1:52 pm
How much did you want to invest in this one?? And from there luck what is out there that give you what you want and give you more for your money.
Good Luck!
geposted Wed 06 May 09 @ 6:37 pm
If you want a work horse laptop look at the dell precision series, They already outfitted with an Nvidia quadro 1G video card. Yes it's expensive but it is a purpose built system and I think it's worth a look if you are planning to use it as your main gear. I do a lot of photography and graphics. I have been using one since last year and it has not failed me yet. I have a separate HD for my graphics and another one for Dj programs, I just switch them over. I still have a best buy special toshiba satellite which works flawlessly with VDJ, but I use it just to do paperwork and internet surfing.
geposted Thu 07 May 09 @ 11:12 am
quad core if your planing to do vid edits
also i find that the key adjust works better with a quad core .
i have a 3.6 dull core that i overclocked from 3 ghz its ok but im trading it in for a 4. 5 ghz quad core
im going to love this. away
just go quad core u will be happier .
a 2.4 ghz quad core will kill a 3.0 ghz Duo core
just check out bench marks and u will see
geposted Thu 07 May 09 @ 3:39 pm
