I have a computer that I haven't used in a long time but it has 4 harddrives of music video and karaoke. Each has it's own database file with the song info, etc. Can I merge all together to put on one 1.5t drive or do I have to rescan everything. Can I just change the drive letter in each xml file to the drive letter of the new harddrive and then copy paste into a new xml file? What happens if the same song is on 2 of the files and there are slight differences in the info? Will this corrupt it? I also want to add the database from a totally different computer that I use now full time 7 on 7 gigging. Has anyone done this? I searched the forum but each time I found something there was no response or clear response to the question about merging. If someone has done this before can you send me the forum link where you have discussed this .
Funkmasterfrank
Funkmasterfrank
geposted Sun 03 May 09 @ 4:40 pm
