Hello,
I have a question.
Can I use 2 PCs in one time ? I mean ... when I use one PC for VDJ, other PC is use for Live Synth Software such as FL studio.
If I use, which setting is the best for Live giggin' ?
Live Synth PC Line Out > VDJ PC Line In > VCD PC Line out > Mixer
(or)
Both PC Line out to Mixer
Plz explain me as I'm newbie in Electronica Music.
Thanks and Regards,
Transa
I have a question.
(or)
Thanks and Regards,
Transa
geposted Wed 16 Mar 05 @ 3:12 am
Hi!
Yes, you can use 2 PC's for live gigging, and for mixing music VDJ is an option. To answer your question, it would be better to use your second suggestion "Both PC Line out to Mixer", for better controll over sound output, and independency between both systems.
I see you would also like to create your own samples and sounds on the fly by using Fruity Loops. Well, FL is more of a music production software, in which you compose a song, but it can also be used as a live sampler with use of MIDI Keyboard. Though I would recommend to look for other live sampling software like Ableton Live (www.ableton.com), M-audio (www.m-audio.com), etc., which are made exactly for LIVE sampling and remixing.
Regards.
Regards.
geposted Wed 16 Mar 05 @ 7:57 am
Don't you like the sampler of Virtual DJ to remix live? Even you win the synchro ;-)
A sampler is a sampler: you can use extract from the song but sounds too like beat or voice
geposted Wed 16 Mar 05 @ 4:13 pm
