i installed the sb scroll text video effect. saved the zip files, unzipped them, then installed but when i went into the video effects screen of vdj it said application could not load because a file could not be found. wish i had better info about which file it said was missing but i closed vdj. has anyone else had problems with this effect?
geposted Mon 04 May 09 @ 1:56 am
make sure your upto date with directx and c++, plus did you miss the sticky scott has specifically made for these type of questions.....
https://virtualdj.com/forums/95136/Virtual_DJ_Plugins/Plugin_not_working__Controls_not_showing_______Read_this_before_posting_____.html
hope it helps...
hope it helps...
geposted Mon 04 May 09 @ 3:36 am
...or you could read the first page of the included documentation...
geposted Mon 04 May 09 @ 6:11 am
