I am using virtual dj with hercules and when i load a track that is around 10 minutes or longer it doesn't load properly with BPM and length. It might load up as 19-40 minutes and it will not show the layout of the track. Also having problems with the tracks not staying a constant bpm, There are slight deviations around the set BPM.
geposted Wed 16 Mar 05 @ 7:23 pm
Hi
You need to configure your max load setting to a higher value than the song loading
You can correct the bpms manually (right clik edit bpm -then change the bpm you will notice the cbgs move.....so simply allign with the beat)by doing this you will have the right bpm
Regards
Andre
Regards
Andre
geposted Wed 16 Mar 05 @ 8:13 pm
