I don't know if this is in the right spot, but here it goes. How do you have the two decks play at the same time? I can't find a way without the BPM being off. Is there a way to play them both at the same time from the start? Thanks.
geposted Wed 06 May 09 @ 6:44 pm
you could try dj'ing...
not sure if it will work for you i know some users here have trouble with it.
geposted Wed 06 May 09 @ 8:25 pm
Easy.. example on the deck a you ready with your mouse to press play, then at the deck b (use tab to select deck b - make sure it is lit) press the spacebar of your bar;)
geposted Thu 07 May 09 @ 12:59 pm
