Well, it might well be faulty video graphics, but... Oh well, over to the problem.
When I try to show a picture (jpg format) through the video effect "slideshow" it shows a scrambled image. If I disable/activate it a couple of times it gradually becomes better until at the third try it shows perfectly. Any idea what can cause this?
I've also had some problems running karaoke files in wma format. On some songs (I didn't think to double check if it was consistent on those files, or if it was a random thing, will try to check that next time it occurs) the rightside 30% of the screen shows scrambled colours (about as it was on the old tv's if you hadn't tuned your channels correctly). Again, any idea about this?
geposted Thu 07 May 09 @ 2:48 pm
