hi folks,
i have a problem i cant delete Playlists
means the menue shows me delete option but
if i choose it nothing happens
is there anybody with the same problem or is it a known
problem???
thx
bodo
problem???
thx
bodo
geposted Fri 08 May 09 @ 7:32 am
Same thing for me. The only way to delete the playlist is to go to the actual "playlists" folder in VDJs system folders and throw the file in the trash.
geposted Fri 08 May 09 @ 1:44 pm
That is how u do it go to the folder of VDJ open it and then open play list and delete your play lists its the only way to do it
geposted Mon 30 Nov 09 @ 11:36 pm
