ive been looking for a wireless internet radio player that i can just use for listening to vdj radio or any other internet radio but couldnt find anyone that i can actually type the URL of it and play it...any ideas?
geposted Fri 08 May 09 @ 5:05 pm
You can buy used Windows Mobile cellphone (samsung blackjack, t-mobile dash....) for around $80 using craigslist.org and connect it to the speakers. Most of those phones have wi-fi built in. They will play shoutcast streams (VDJ radio) with free players (GSPlayer).
I actually connect my phone even to the car speakers and listen internet radio (up to 64kbps streams) using cheap T-Mobile internet (not 3G). Radio stations in AAC+ format sound pretty good.
geposted Sat 09 May 09 @ 12:10 am
Hi Marine,
hope you are fine ;-)
There are a lot of wireless radios avilable
I can give you two links!
Inside you can have a look, what's up to your chioce!
http://www.pure.com/digitalradio/
http://www.radiostore.de/shop/Radios/Internetradio:::1_88.html?XTCsid=aca14e1b24f22b8995d07c73839a2d4a
Sorry, the second link is only in german.
Haha, doesn't matter, search for the modell/type in the internet!
I have bougt the Albrecht DR-315.
It have all kind of needful Radiofeatures inside, UKW, DAB and Internet WLAN.
Also two chinch outputs for a connect to my amps!
Keep your head down and take care!
See you on radio!
Haui aka LB :-)
See you on radio!
Haui aka LB :-)
geposted Sat 09 May 09 @ 1:50 am
thnx for the input but i know theres a lot but i needed one that i can actually put a link in the radio and it'll play it not some preset radio..i wanna give that to my mom so she can listen to her indian channel radio etc in the kitchen and i have the link for it ..HAPPY MOTHERS DAY lol
geposted Sat 09 May 09 @ 10:27 am
