I've been using VDJ for about 2 years now with great success. The problem is that I dumped my hard drive for a new one, reinstalled windows xp pro and all the goodies, reinstalled VDJ. I downloaded 2.06,and a couple of skins that I've always used. (Tascam etc.) I also downloaded a couple of new ones to try, but they don't work. I noticed that they are not in a zip format like the older ones. Rezipping did not help. Is there a trick to get the newer skins to work?
geposted Thu 17 Mar 05 @ 5:49 am
i downloaded the last 4 skins this week and they where all zipfiles....
geposted Thu 17 Mar 05 @ 7:01 am
You should probably re-download them.
When finished downloading them, don't choose "open"
just save them as they are in your skins folder.
geposted Thu 17 Mar 05 @ 6:20 pm
It happens sometimes that when downloading skins, there is no extension (".zip") added to a filename, thus making it unreadable for any software. So when you do download, just add the ".zip" at the end of the skin name, otherwise you'll have to rename it with windows' explorer (which you won't be able to do if "show file extensions" are disabled in options).
It' basically a naming problem (server/forum code). And it IS a zip filetype what you have downloaded.
geposted Thu 17 Mar 05 @ 7:57 pm
This is a problem downloading skins with anything other than IE use internet explorer to download skins.
geposted Fri 18 Mar 05 @ 2:18 pm
Open the skins folder and make sure the extensions are there. If not, add them. That worked for me.
Now-
If someone would please add a headphone slider on the default skin I would be most appreciative...
Now-
geposted Fri 18 Mar 05 @ 7:23 pm
