Hi,
I tried to buy Virtual Vinyl in the UK today and I was told by one of the shops its been discontinued. I was wondering if anyone knew if this was true and if its due to be replaced with a new version or has it been completely discontinued? Any info would be a big help!
Cheers
Dan
Cheers
Dan
geposted Mon 11 May 09 @ 1:23 pm
If I was you, I would get in contact with Numark and see what they say on the matter.
geposted Mon 11 May 09 @ 1:28 pm
You can achieve the same thing with the right sound card.
The pro version supports time code just like VV does.
geposted Mon 11 May 09 @ 1:29 pm
But be carefull:
the normal VV has 1100 Hz (Sine on the Vinyl) but VirtualDJ needs (in my case, tryed it with synthmaker) 1050 Hz...
May be, that's shit... but i tryed with a standart VV (1100 Hz) and my song wa too fast. So i calculated it down and then i came to 1050 Hz on the dot.
geposted Mon 11 May 09 @ 1:36 pm
Virtual Vinyl is not discontinued we are Just temporarily out of stock.
geposted Mon 11 May 09 @ 4:32 pm
Great thanks for your help, I thought it was unlikely it was discontinued.
Cheers
Dan
Cheers
Dan
geposted Mon 11 May 09 @ 6:14 pm
