hey everyone my name is dj jon, i have been using virtual dj for about 6 months now and really enjoy it, i am recording a mix using the cd part of virtual dj which allows me to record my mix and cut the part where i want it to be a new track. that works fine but when i go to open it up it takes me to rocio and does not support it. i was wondering if anyone new of a different software to use so i can make a mix tape and still be able to have the individual tracks. Please help me
geposted Wed 13 May 09 @ 10:03 pm
I suggest you record your mix as a single WAV file and use a wave editor (Sound Forge, Audacity, Goldwave, etc.) to cut your WAV file into separate WAV-files and then burn them to CD as tracks.
geposted Thu 14 May 09 @ 2:09 am
Hi use the trial version of Sony CD Architect allows you to cut the tracks but not interupt the mix as in purchased Cd's
geposted Thu 14 May 09 @ 6:49 am
instead of using the "Record CD" part of VDJ use the "mp3" part..
This will give you a bunch of MP3 tracks labelled in sequence that you can then put together and burn using your favorite burning software..
geposted Thu 14 May 09 @ 10:14 am
look up power iso or alcohol 120 that should help you out..peace
djreaper
djreaper
geposted Thu 14 May 09 @ 11:18 am
+1 for power iso
geposted Thu 14 May 09 @ 12:16 pm
