Hi ive had a look though the forums and cannot find my answer so I will ask away.
Basically I want to set the bpm's for my tracks to 160 bpm and burn them all to CD and/or save the new bpm's to the master files on my pc, so that they are all the same speed regardless of if I am using VDJ or just playing the tracks on a cd player.
What is the simplest way I can do this?
Many thanks.
Many thanks.
geposted Thu 14 May 09 @ 11:44 am
Why would you want to set all of your tracks to the same BPM?
geposted Thu 14 May 09 @ 11:46 am
I could go into a really long indepth answer but in all honesty it comes down to not wanting to time up every track. I want to play about with effects,loops and samples whilst mixing without having to worry about it.
if I were just using VDJ then it has this function already but I would like them on cd also.
geposted Thu 14 May 09 @ 11:54 am
