I am doing my first club gig and the only connection they have is an XLR Female in the wall.
I am using and Ion iCue with laptop and have a Maya 44 soundcard.
How do I connect to it?
Thankyou...
Thankyou...
geposted Thu 14 May 09 @ 3:44 pm
Something like this??
http://www.djstore.com/item/procabl67.htm?affid=froogle
geposted Thu 14 May 09 @ 3:51 pm
You will probably need some thing like this.
geposted Thu 14 May 09 @ 3:52 pm
I think this is it, I shoud be able to patch stright into the maya with this!
Thankyou!
geposted Thu 14 May 09 @ 3:56 pm
Yes, Output 1&2 ( I think, lol)
geposted Thu 14 May 09 @ 3:58 pm
Thankyou...
Thankyou...
Is it a single or dual XLR?
If its just a single, check to make sure its not an Mic input! its rare but if it is a mic input you also need to make sure its not phantom powered! (many places with a single XLR on the wall are usually wired into the high-z mic input, line level signals will usually sound terrible/distorted, and if its phantom powered, you may just shove 48 volts into your maya44!)
Your best bet (to go from RCA to XLR) is a DI-box
geposted Thu 14 May 09 @ 4:51 pm
