How do I set up my BCD 2000 to work with vDJ 5.2
(Sony Viao with Windows Vista)
Thank You
PS: please post a detailed message im not a computer expert
Thank You
geposted Fri 15 May 09 @ 10:09 am
The bcd2000 doesnt have a vista driver on the behringer website which meens it is not compatible with vista.
The bcd3000 is the newer version that is compatible with vista although if you search google some people have got the bcd2000 working on vista but had problems with reliability and getting the lights to work on the bcd2000.
I myself had one and gave up with it as i had problems with it so i brought the numark total control
geposted Fri 15 May 09 @ 10:37 am
i managed to get it to work decently reliable on vista, i did however have to map every button, knob, fader, and jogwheel. the lights did not work and also was unable to use headphones, it worked ok but i still upgraded to the RMX. PM me if you would like the xml file for the bcd2000.
geposted Fri 15 May 09 @ 5:44 pm
