Hi,
I have recently bought 2 new virtual dj virtual time code vinyl's and a Acura vinyl player, i already had a hercules rmx with virtual dj pro wich worked fine for all the time, but now i've tried to get started with the time codes i've run into some problems.
First off, i found a guide for the time code vinyl's and the rmx/mk2 setup's (by skyfxl) and tried to get it runing, but i keep getting 0% on my signial, here are some pictures from my settings
http://img40.imageshack.us/img40/6540/virtualtimecodeproblem.jpg
http://img32.imageshack.us/img32/8054/virtualtimecodeproblem2.jpg
I've even tried to reinstal my virtual dj pro, the orginial virtual dj deliverd with the hercules rmx and installed the latest drivers.
Any one got some info how to get mysetup running?
geposted Fri 15 May 09 @ 12:13 pm
In the timecode config try this
Change the timecode engine to VDJ timecode V4.
Check the Software RIAA preamp option, uncheck Clear Sound. Then click Auto config and see what you get.
geposted Fri 15 May 09 @ 12:20 pm
I tried the options you checked and still it didn't work. it gave the message: Error in Asio Driver
http://img31.imageshack.us/img31/4567/timecodevinylprobleem2f.jpg
geposted Sat 16 May 09 @ 2:32 am
I found out what the problem was, it turned out for some reason my input 3/4 is broken or something, i switched my timecode to channel 1/2 and got a signial right away.
geposted Sun 17 May 09 @ 3:38 am
I using Hercules RMX and Gemini CFX-30. the TCCD what, however I keep getting feed back, long beeping noise. I can heard the sound , but rhe lond feed back sound drowns it out. any suggestion
geposted Sun 31 May 09 @ 6:21 am
