Hi all,
I'm looking to buy a secondhand Imac to have setup in the spare room and have found one within my budget.
Question is - is this spec any good to run VDJ? I use an RMX and I don't do any video mixing, audio only.
G4 7445 - 1.25Ghz Processor
512MB Memory (Maximum of 1GB)
80GB Hard Drive
OS X 10.4.11 (Tiger)
Any comments appreciated
80GB Hard Drive
geposted Sat 16 May 09 @ 11:48 am
Hi richphillips,
This are the recommended system requirement on mac.
Mac OSX 10.4.7 or higher
Mac/Intel Core Duo 2.0 GHz or higher
1 GB RAM of higher
200 MB free on the hard-driver
Minimum system requirements on mac.
Mac OSX 10.4 or higher
G4 1.5 GHz or Intel Core Duo 1.6GHz
512MB RAM
Regards;)
1 GB RAM of higher
512MB RAM
Regards;)
geposted Sat 16 May 09 @ 4:05 pm
thanks spinnaJ;)
so will having a slightly lower processor than the minimum mean that VDJ will refuse to run or just not run as well??
geposted Sat 16 May 09 @ 4:52 pm
Hi,
Having the slightly lower processor, i can't guaranteed that it will fare good or average with VDJ even only for audio.
And I honestly suggest it be better if you buy a new imac or just the new macbook etc. It quite affordable these days;)
geposted Sat 16 May 09 @ 5:58 pm
