Hello,
While I did my video gig, the pitch level was changed every time I loaded a vid.
The problem was that I could't bring it back to normal. I count get the glider to another position.
So I had to restart vjd and then it was gone.
You know why this happened?
geposted Mon 18 May 09 @ 4:12 am
Same thing happend to me last week. Only restart helps. :-(
geposted Tue 19 May 09 @ 9:49 am
Yep,
You're right.
Strange that nobody knows the answer.
You're right.
geposted Tue 19 May 09 @ 12:22 pm
Happened to me as well.
If it happens again; Try clicking the "SYNC" button so it will disengage. It appears to mysteriously engage on its own.
What was happening with me is that any video/mp3 I loaded would automatically try to SYNC to the same pitch of the already playing video.
Nothing helped but to restart. Luckily, the couple of times it happened was at the end of the night.
geposted Tue 19 May 09 @ 11:10 pm
Thanks Diamond G,
Gonna try that the next time.
I always have a cd ready for emergency, so I played a cd and quit vdj and restarted it.
geposted Tue 19 May 09 @ 11:50 pm
Damn... What a strange thing this is because this past Saturday it happend to me and the only thing that could be done was reload the program. who was using a controller vs TC
geposted Wed 20 May 09 @ 1:26 am
I was using NS7
geposted Wed 20 May 09 @ 6:48 am
I was using controller, mouse, and keyboard shortcuts.
Last I remember: I loaded a song while another played, cued, mixed in cued song (everything fine), looked away to take a sip of my adult beverage then looked back and the SYNC (Deck 2) was mysteriously lit. Repeatedly clicked on it but wouldn't disengage. Restart.
geposted Wed 20 May 09 @ 7:37 pm
I was playing vids.
Don't remember was I did at that moment but changing the pitch to normal didn't work.
It looks like a auto sync every time you load a new song or vid.
But how it happen, I don't know.
geposted Thu 21 May 09 @ 1:39 am
there is a keyboard shortcut i beleive that engauges auto-sync. I think if you hold either SHIFT or CTRL and click the sync button it turns it on and off.
geposted Thu 21 May 09 @ 3:59 am
Thanks mate.
Gonna write it down for the next time.
Hope it works.
Hope it works.
geposted Thu 21 May 09 @ 4:05 am
