Due to travel at the moment I don't have any turntables with me. So, I am solely using my HC4500 in combination with my DNX500 mixer and a laptop.
So, I am using only the HC4500 soundcard configuration with external mixer mode. I keep getting a continual problem that is pissing me off big time!
Everytime I get my 2 songs in sync and on beat. I begin mixing over to the other side and it continually either speeds up or slows down as I get almost to the other end.
This is extremely annoying, does anyone have any idea why this is happening? Do I have something setup wrong or is it a bug causing this any input would help thanks.
geposted Tue 19 May 09 @ 1:25 pm
I've searched threads about this issue and I can't find anything simillar to this. It's kind of odd, actually I also noticed the bpm would just change on it's own at times.
Guess it has a ghost inside the HC4500 hahahahaha..........
Well after messing around with the latency for awhile and reseting a few times and unplugging everything, I did get it to stop finally. I had my performance tab set to :
AUTO, SLIDER ALL THE WAY LEFT, AND THE OVERCLOCK CHECKED
ON THE DENON ASIO IT WAS SET TO 513MS AND I TRIED IT ON VARIOUS SETTINGS NOTHING WORKED
FINALLY I CHANGED THE PERFORMANCE TAB FROM AUTO TO 64MS AND DENON ASIO TO 1024MS AND IT
STOPPED.
Seems to just be a latency issue hopefully in the near future with the new VDJ all this tweaking will cease hahahaha........
Well, hopefully someone can gain from this info :)
STOPPED.
geposted Thu 21 May 09 @ 12:37 pm
