Is there a way to change the colors of the icons next to the tracks? I guess my eyes aren't what they use to be; I've been having trouble telling the difference between karaoke and video tracks at a quick glance when I do a database search. Is there a way to, say, change the color of the unplayed video or karaoke tracks in the DB? Or is this issue being addressed in future releases? Thanks.
geposted Tue 19 May 09 @ 4:45 pm
the iscons are drawn on the .BMP file for your skin, in the lower part that is not seen (as VDJ shows the top part, and uses the bottom to make the graphics come alive.
If youre brave enough, you could open the .BMP file in a graphics editor and you will find the icons near the bottom somewhere there.
but if you simply want to make the icons biger, then have you considered making the browser text slightly bigger? as this will make those file icons larger, too.
If you need a hand with this, then send me a PM.
geposted Tue 19 May 09 @ 7:12 pm
Also, you could enable the 'filetype' field.
this will show you your Karaoke as .ZIP or .MP£, but might help you notice that .VOB and .MPG and .MP4 are not to be sung.
To this, right click the bar with artist in the browser and select fiiletipe on the popup menu. there is an option at the bottom to open a window where you can change the order of the columns.
geposted Tue 19 May 09 @ 7:50 pm
