Ive read on other forums that they also have the same problem when hitting the stutter it start about a half beat before or after the cue point and im the type of dj that uses this ALOT. so i was wondering if there is a fix for this bug yet i am running vdj 5.2 on Windows XP pro sp3. Amd turion 64 mobile, 1.58 ghz, 2 gb of ram.
any help is appreciated other than this issue i think vdj is the best software ever....=]
geposted Wed 20 May 09 @ 1:01 am
Register your license here with us and grab the latest version (v5.2.1) and see if that helps.
I've not heard anything about this bug; I've used stutter a lot and mine always starts on the cue point.
geposted Wed 20 May 09 @ 6:51 am
Ok I will try that thanks
geposted Thu 21 May 09 @ 3:02 am
